Does anyone have any recommendations on textbooks relating to this area ?
I'm thinking along the lines of DPA type RF mains filter boxes.
http://cgi.ebay.co.uk/ws/eBayISAPI....MEWA:IT&viewitem=&item=290070973248&rd=1&rd=1
Hi
Seller has no claims on what the units does or how (true black box special) quote from seller "It has no voltage or power rating specified so I guess it will work on all voltages" is this a joke ..hahaha.
Anyhow.. you can buy very good mains filters from outfits like Corcom and others with international approvals with ratings for loads and filter effectiveness (VDE class B is best). as an example you could put it in a box with IEC connectors and step down isolation Xfrmer.
see link http://www.cor.com/
No it's not a joke, the DPA 'The Power' were well-regarded in the UK.
The DPA filters are a discrete circuit of five or six (can't remember) cascaded differential L-C sections, based on hand-wound aircore chokes and caps that stepped down in size to the outlet. Somewhere I have the schematic, which I traced. Personally -tried one, didn't like it - but then I don't like the effect of any forms of mains 'conditioning' I've tried yet (I think you lose more than you gain...)
BTW Ash- Chevin Audio in the UK do a unit which looks very like 'The Power' BTW, at no premium over what the real thing goes for on ePay.
martin clark said:No it's not a joke, the DPA 'The Power' were well-regarded in the UK.
Thanks I'll take a look
the UK seller seems to be non techy so I guess when he says all voltages he means all UK voltages (220Vac to 240Vac +- tolerance) and all lower voltages used around the world.
I think the use of IEC plug and socket outlet indicates conventional mains voltage.
I think this is no joke.
