Hi, is anybody familiar with Sfernice RCMS05 resistors for audio? see datasheet:
http://www.chipcatalog.com/Doc/5F011CB489222E1EB71250CEC9405A16.pdf
Thanks, Loek
Thanks, Loek
In general, metal film resistors have a high parasitic inductance compared to carbon types. This can adversely affect your high frequency response if they are used in the signal path.
Generally, you don't need the kind of temperature stability that is the real advantage of these type of resistors. 1% RNC types should do a fine job and cost less.
