I made a shunt passive preamp, 10k resistor into 10k log pot and tried different series resistors.
Dale RN 55C - sound good
Dale RN60D - sounds relaxed but less good
Sfernice very low ppm metal film - sounds horrible 9 hours ago but keeps improving - now sounds very good and from memory rivals Vishay VSRJ.
How can the sound of a resistor change so much over 9 hours??? The volume setting has remained the same.
There is also a difference between a pair of Tiffany gold plated brass RCAs and the Kimber RCAs, with the latter sounding more 'relaxed'. Mounted next to each other and with same solid silver cable.
If there is such a difference in voicing for a simple passive, what chance have we of getting more complex circuits to sound right except by trial and error???
Resistor Sound - How is this possible???
Rediscovering stuff that has been known for 30 years? Or just looking for a fight with one of them scope-heads?
fmak said:How can the sound of a resistor change so much over 9 hours??? The volume setting has remained the same.
Not that a resistor can't chage over time, but why assume that it's only the resistor that has changed? Over the period of 9 hours, many things can change. Temperature. Humidity. Ambient noise levels. Power line noise. Etc. Not to mention all the various physiological changes that we humans undergo during the course of a day. And on top of all that we've got an aural memory that's not very good with regard to low level differences and is susceptible to false memories just the same as other memory functions of the human brain. And we haven't even got to the part about all of the various influences which can affect our subjectve perceptions.
Given so many variables involved (more than I've mentioned), I've a hard time understanding how assuming it's the resistor that has changed is any sort of safe assumption.
It's certainly a safe enough assumption from the point of view of what spins our respectie audio beanies at the end of the day, but in terms of trying to get at what's actually going on, I don't see that it's any safer an assumption than a dozen others.
se
---------------------Raka said:(whispering: Pss, eh! yes, it's me, could you please tell me where do you buy Dale in Europe? Sorry for the off-topic)
Yes, thru Farnell but they now charge £12-50 for delivery. Before nothing.
------------------------------------Raka said:Thanks,
They have the Dale CMF-55, are they the same?
Not sure of the no but I think so. The C is 25 ppm.
Re: Re: Resistor Sound - How is this possible???
The scientific approach assumes that one has to prove everthing. The issue is:-
Swapping the resistor to another one restores the original sonics after x hours. That is the proof of the pudding.
I am an engineer who makes values judgements as well as scientific ones. If something is real, then it is and I don't go around making all kinds of irrelevant assumptions such as temp change when the resistors are 25 to 2 ppm . My power supply is also well filtered and the raw feed is bad at all times. Noise level and humidity don't change much in England either - we don't have air conditioning.
Not rediscovering but was astonished by the magnitude of the difference with the Sfernice
Scope-head! Burn him at the stake!
Hardly "irrelevant". You're viewing only a resistor variable. This is the one variable view that Steve discussing. Thermal biasing of the transistors is clearly relevant.
Please NOTE that it is a passive preamp with one series resistor I am on about.
fmak said:If there is such a difference in voicing for a simple passive, what chance have we of getting more complex circuits to sound right except by trial and error???
Hello -
Trial and error is really about the only way to get started. Eventually you will see some patterns emerge, which will speed things up in the future. It is surprising the degree of improvement that is available through "passive" components. One thing is certain -- we'll never run out of ways to improve audio products!
Best regards,
Charles Hansen
PS -- I say ignore all those postings that presume the differences are only in your head. Perhaps it is those posters themselves that are only figments....
Re: Re: Re: Resistor Sound - How is this possible???
And the religious approach assumes that nothing need be proved.
So which realm are you in here? The subject seemed to imply the former, but this post seems to indicate the latter.
But what exactly is the pudding? Is the pudding simply your own subjective experience irrespective of what may actually be occurring, or is the pudding trying to discover what actually is occurring?
Real in what respect? Real with respect to your subjective experience or real with respect to the actual cause of the effect? The two aren't necessarily one and the same. Assuming they are is a poor assumption if the pudding is trying to discover what actually is occurring.
England also has Peter Belt, who has proved beyond any doubt over the years that Brits are just as susceptible to the same sorts of psychological phenomena as everyone else.
se
fmak said:The scientific approach assumes that one has to prove everthing. The issue is:-
The issue is:-
se
thylantyr said:I agree with Steve.
Since your mind is determined to listen to two resistors
and you try hard, you will think you heard something
much like people who stare at a statue for a while
and think they saw it move.
Jedi Mind Tricks
But I'm not assuming that the phenomenon is purely psychological. That would be just as silly as assuming that it's not.
All I'm saying is that there are too many variables unaccounted for to come to any meaningful conclusion. At least any conclusion beyond one's own subjective experience.
se
SY said:Scope-head! Burn him at the stake!
Yikes! That's downright Medieval. Can't the church just place me under house arrest like Galileo?
se
- Design & Build
- Parts
- Resistor Sound - How is this possible???
