Replacing KT88 with KT90 - Beginner's questions
Hi
i have at last fixed my valve amp, thanks to the advice I received here (details of amp etc here:
http://www.diyaudio.com/forums/showthread.php?s=&postid=1324871#post1324871
I am now thinking of putting some better tubes in it. first on the agenda are the KT88s. These are cheap chinese ones (as far as I can tell - they have 'National' on them in red script). I read that Electro Harmonix KT90s are a direct substitute and won't require any alterations beyond rebiasing. Is this the case? Will they give noticeably higher volume levels/sound better or should I stick with KT88s? EH, EI, Sovtek?
Please bear in mind that I am a beginner and much of the tech talk on this illustrious forum goes straight over my head! I asked a question about equivalents for the input valves on the amp (6N2, 6N6 and 6N11) and ended up more confused than before i started! - Yes, you can replace x with y - no you can't, that valve is not the same, but you could replace it with z if you rewire your big end. 6N6 = 6N6P - no, not exactly true etc etc.
There does seem to be some disagreement when it comes to substitution of chinese valves. This, I think, was as close as I got to a consensus:
6N2 can be replaced with ECC83 or 12AX7, but the valve base will need some rewiring.
6N6 has no direct equivalent, but closest match is E182CC. This might require changing the circuit in the amp.
6N11=E88CC or 6922.
Assuming the above is correct, does this mean that I can simply pull out the 6N11s and replace them with E88CCs or 6922s without any modifications? If so, are there likely to be any sonic benefits?
Likewise, I could get a local valve tech to rewire for ECC83 or 12AX7 to replace 6N2, but again, would it be worthwhile?
As ever, I am grateful for your advice. I am learning how to solder (properly this time!) and one day I dream of having sufficient skills to build a valve amp from a kit......
Cheers
Martin
I have 5 pair of KT90's sitting in a drawer doing nothing. I bought these thinking that I would replace the KT88's that I am tunning in my Quicksilver mono block amps. I replaced them with the KT90's and was disappointed with the results as I lost midrange and hi frequency detail and went back to the KT88's and 6550's I had been using. I am told there is a slight power increase to be had by using the KT90's but seriously doubt that it would even be noticeable. My suggestion is to replace the KT88's with a set of good 6550's or KT88's. I personally like the Sovtek brand but there are others out there just as good.
Good KT90s (those made by EI before the NATO action) are a thing of the past. :( Post NATO action EI and all EH KT90s have problems, either in electrical behavior or in sonics.
3 NICE big beam tetrodes are made in Russia. The EH and GEC "reissue" KT88s come from the Saratov plant. The SED (=C=) 6550C comes from the St. Petersburg plant.
If you can afford 'em, buy the GEC "reissue" KT88s.
Thanks - that's two votes for sticking with KT88s. I'll have a look at the prices - the EH ones are reasonably affordable here in the UK, but I'll check out the GEC reissues as well.
Further questions: how much of a difference will changing valves make to the performance of the amp - are we talking huge improvements or more subtle ones?
Which valves tend to have the greatest influence on sound quality - signal or output tubes?
Sorry, like I said, I'm a beginner......
Many thanks
Martin
burnedfingers said:
I have 5 pair of KT90's sitting in a drawer doing nothing. I replaced them with the KT90's and was disappointed with the results
Copy that.
The Russian new made KT88's SEDS have a decent thick envelope (far thcker than NOS) and are well made for rigours around the bench.
KT90's would be fine for a tasty power supply project, that's about it.
If you insist on using them in audio, expect double the output stage THD compared to KT88's in a standard UL p-p stage. There will also be roughly 15% more output power in LS.
richj
I would agree. Keep the KT88's. They are great tubes.
I only know of one amp that probably runs better with the KT90 - because it was designed with exactly that tube in mind. That amp is a Jadis ;)
My advise would be to cook your tubes as described by Morgan Jones in his very fine book.
Put them in a dish (not covered) in a cold oven and turn on - bring up slowly to 150 degrees celcius and keep there for 4 hours. Then turn the oven off and let everything cool overnight. Don't move those tubes out of the oven until they are cool. This really works wonders with old tubes and doesn't cost you anything. I actually go to 200 degrees celcius for 2 hours, but this may brown the lettering on your tubes...
Make sure the oven is clean before you do this or you will get chicken/porkchop flavoured tubes... Also, Get the OK from your wife/spouse/etc before you start baking tubes... :rolleyes:
Thanks - putting tubes in the oven, eh? is this the sort of thing my wife is going to have to put up with if I go any further down the valve road?
I can see her rolling her eyes as I type this.....
As for the output transformers, I don't know. The amp is a bit of an enigma - I've never found any reference to it anywhere.
Martin
salas said:
My neighbor runs a Jadis DA-30 that came packed with EI KT90s. He has recently got a Jadis red logo JJ KT-88 ultra matched quad and the amp sounds markedly better with them.
This was according to my ex-boss who also owns one :rolleyes:
My point was that the KT-88's in it will sound better.. But I think a lot of $$$ wasted on new KT-88's can be spared by a proper heating cycle.
I'll take the old valves off his hands for free ( - a one time special offer) if he is willing to post them to me. :D
If the KT90s you put in were EH, I'm not surprised at the results. They are well made, durable, and sound blah - really poor imaging is the worst of it.
richwalters said:
Copy that.
But the SED KT88 is SO rolled off on top, I can't even stand to listen to them. I think they are muddy, tubby, and unless you have a really hot top end that needs cooling off I don't understand what people like about them. Unless they think tube sound SHOULD be rolled off and flabby like Grandma's old console stereo...
A well made, pre-NATO intervention Ei KT-90 is the finest of the KT-88/KT-90/KT-99/KT-100 tube type I've ever heard. But the Ei stuff that you can buy now has misaligned screens and will "red plate" at 50-60% of rated dissispation. They also will have higher THD.
My response to this is > depends on amp circuit, esp driver design. I run my amp in class A p-p UL and swapping any make KT88 with an 6550 I get immediate dynamic improvement. I have also noticed subtle differences.So what does it ? Measuring thd is already very low, albeit swapping the 6550 in lieu offers even lower thd. I strongly suspect the "sloppiness" with 88's is associated by running them with low too quiescent which creates high thd at high frequencies and ruins definition. (OMO).. So I run above mentioned power tubes typ >B+ at 370V,
I quies at 85- 95mA.
With this disipation there is no advantage to use Morgan Jones technique of cooking the tubes at 150°C before use. Or is there something in the receipe I've missed ?
richj
richj
Rich,
The KT-88 SED sounds horrible to me in any amp I've heard, including the Citation II - which has bandwidth up the wazoo and very stout drivers.
Your second observation is interesting - the Cit II (which I specialize in) bias I recommend is 85 ma with KT-88 or 6550. The B+ voltage is about 455-460 volts on those. Intersting we ended up so close on that...
