so i recently replaced the driver and output transistors on the 730 because i shorted them out a while back. anyway, the amp is working again.
there is another problem. when i power on the amp with either speakers or headphones connected there is a hissing noise for a couple seconds in the left channel then it ceases. there is then a hissing noise in the right channel then it ceases.
any ideas what could be causing this?
edit:
the hissing noise is a large temporary DC offset ~100mV reaching the speakers. any ideas what could cause that?
edit:
