I'm thinking of trying some bi-amping with my Gainclones and an active crossover. I've settled on the crossover, but not the power supply. I've been doing some searching and haven't stumbled upon a simple solution. I'd like to find a +15v -15V regulated power supply PCB, or kit, that somebody has prototyped and procured a few of, similar to what Brian has put together for the LM3875 gainclones. I've seen a few designs, and I guess I could point-to-point something, but if there are PCBs, or kits, available in the U.S. market that would do the job, that sure would be easier.
Try Hagerman Bugle Power supply kit.
Jim Hagerman has a 15 + 15 - kit that he sells for his Bugle Phono Preamp. You can adjust the voltage if you want more or less than 15 volts.
I've built one, but I haven't drilled the holes for the chassis yet (my least favorite part of building), so I haven't tried it out yet. Hagerman has a forum at Audiocircle, and he is very quick to respond or help with parts substitutions.
The board is $25, and the parts are all available from Digi-key.
http://www.hagtech.com/bugle.html#powersupply
-Aaron.
-Aaron.
check out circuitspecialists.com
http://www.circuitspecialists.com/level.itml/icOid/4078
kit 124 and 125 work well. I used them in a preamp last year. No problem yet! All you have to do is supply the appropriate xformer.
Greg
Greg
another option for small simple +-15 using 317/337 is on this page. no pcb, but it goes together quickly on perf board. you can get all the parts from digikey.
http://headwize.com/projects/showfile.php?file=stokes_prj.htm
add small heat sinks to the parts lists. doesn't need anything fancy. i'm using it in a meta42 and it barely gets warm.
- Chip Amps
- Regulated PS Kit
