I don't look that much at the phase noise spec, but instead at the jitter specs. Here the Si514 have max 1 pS RMS, while the best SPDIF receivers have 50 pS RMS, and many people seems to be happy driving a DAC chip directly from a SPDIF Receiver.
The big question is: What can you hear ? I have searched the web and found references to a number of studies, they varied a lot, with hearable limits of 20 pS to 250 nS, with the most credible ones with hearable limits in the nS range.... So I consider 1 pS RMS jitter to be perfectly fine. Especially as once the clock goes though the digital logic it is not 1 pS anymore....
Specs aside, I one thing that intrigued me is Iancanda's experience with his Si570 clock FIFO, whilst it sounded superbly musical with a sweet spot did not quite match a real live play. When he eventually swapped for a Pulsar Clock the latter sounded closer to the real thing
Maybe there are other opinions but I think there is scope for improvement.
Jitter is the integration of the phase noise, almost the same thing.
1 ps of jitter measured for the Si514 would sound wonderful, but is not real for audio DA conversion.
See post #414, the jitter was measured integrating a bandwidth starting from 12KHz, the Crystek and other oscillators was measured with an integration bandwidth starting from 10Hz or below. There is a reason for that.
Master Mode
Hi Søren,
Sorry to bombard you with all these questions but I find this Master Mode very interesting:
If setup this way can your DAC then take dual external clock inputs 49.xx/45.xxMhz instead to drive itself? (the on-board Si514 removed or disabled of course)
The CKSEL from your DAC selects the appropriate XOs
Please check and advise
the DAC can also output a master clock and do have a pin for selecting between 45.1584 and 49.152 Mhz (can be divided).
Same master clock output is also used when connecting multiple DAC's, t.ex. for digital crossovers.
The DAC design itself is not bound to clock frequencies, but in master mode I'm expecting to support 45/49 from the Si514 ...
Hi Søren,
Well it kind of does not matter, since unless Soren puts a reclocking flop after the FPGA, the jitter from it is likely going to swamp all other efforts. It would be so simple to put a nice flop (maybe Potato chip?) after the FPGA but before the ladders. Maybe make room by moving that long column of bypass caps (one on every FPGA pin?) to the bottom side of the board since they are probably not doing much good so far away anyway.
I'm still looking forward to getting a board to play with. Not sure it will be monotonic beyond about 17 bits--even being sign-magnitude-- but that's okay.
Just a thought ...
... and since the board is delayed anyway there might be room/the possibility for implementing a means of a superb clock circuitry - also at the "lowest possible" clock oscillator frequencies (?) - so as to possibly make this DAC unique and - within the reason allowed in future guessing - more future "proof" as it appears to also support higher sampling rates than 384 kHz ...
In case someone would make a PC to I2S/SPDIF "connection" e.g. the HQplayer software to my knowledge allows for 1.536 MHz output at 32 bits ...
Cheers ;-)
Jesper
Cheers ;-)
Jesper
Hi!
I apologize for my incompetent question, but could this DAC play DSD format?
Greets:
Tyimo
Not now, but maybe later...
Ray
There is a upper limit of 16.5V, based on capacitor voltage and also to limit loss in linear regulators.
There is a lower limit of 7.5V, based on loss though diode bridge and 5V linear regulators.
Then taking into account line voltage tolerance and transformer no/low load voltage, and we're at 7-8V AC....
As your board can also accept a DC supply, I'm thinking a 7.4V lipo battery of suitable capacity might be good to try.
I have to say that the discussion points on this topic over the last few days have been really interesting and revealed more of the thinking behind this excellent concept as well as some more possibilities. Thanks.
Ray
Hi Søren,
Since the onboard clock, the i2s pins and some gpio pins all goes though the FPGA, there is nothing, except a little more FPGA work and uC coding, to stop me from adding an option of using external clock, much like most regular DAC chips....
The reason why I integrate almost everything is to make this R-2R DAC easier to use and therefore accessible to more people.
I'm pretty sure that the FPGA itself do not add more jitter than discrete logic chips....
The DAC will not be be monotonic down to more than maybe 14 bits, but thanks to the sign magnitude principle those 14 bits will still be there at the -60 db level, and it will be level linear down to the last bit, way below noise....
Søren, does this mean you will make the changes required to facilitate an external master clocks option or that you won't? I can read it either way.
Does having the option to use external clocks preclude your DAC from being easy to use?
Ray
Excellent! Thanks for considering this option
Of course, it is good to have the on-board clock as factory default so that users will get a known good system to start with ....
Thumbs up from me as well for considering this - hope it will be possible ;-)
Jesper
Hi Soekris,
Would you let us know when these boards will be available on your webshop ?
A pm will be much appreciated.
Tibi
Check out the Nov 6th update on post #1.
Soekris posted on Nov. 9th that there were further delays in resistor delivery, so it's unlikely the information in the Nov 6 update is still correct.
The Nov 6th update describes how ordering will work, not precisely when.
Ray
Don't be surprised while LSI with various internal switching will add internal power noise and this will generate jitter on the internal level switching... that's why in the old days the output signal has been latched with the master clock.
Additional, do not ignore of the generated HF... it will always follow from the source to a sink... meaning it will follow to the connected systems.
Just my 2 cents
Hp
Ray
The person you responded to asked WHEN the boards would be available... A fair question I would have thought in light of the announced delays in resistor production.
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
