I got a great deal on a 230VAC 160VA toroid from Newark, not realizing that the VA rating would drop running on 115 mains. I now understand that . So I picked up one of these beasts:
Audio Power Transformer 550VA, 59V AC output, Great For Amplifier Projects
The manual and many posts here are clear on how to hook up the center tap. Now, my question:
Since I have such an overvalued transformer, is there any benefit to using both rectifier boards? And if so, how would I hook it up? I understand the risk of thermal/current runaway with parallel rectifiers, so I'm wondering if there would be a better way to do it... or maybe the center tap admits some simple solution. What do you think?
That 59Vac transformer is actually a 59Vac centre tapped transformer. More often specified as 29.5-0-29.5Vac transformer.
The 29.5Vac only happens when the supply is exactly 115Vac and the load is a resistor that draws exactly the rated current (9.32Aac) from the transformer. You may find that this same transformer when idling along on almost silent signal and maximum mains voltage supply is putting out ~+-45Vdc across the smoothing capacitors.
29-0-29Vac is very high for any chipamp. Check the 3875 datasheet for maximum DC supply voltage to suit different speaker (load) impedance.
Check Peter's guidance document.
