I experienced something similar while modding mine; most opamps are bypassed with relatively low values. I changed two 10uF bypass caps for 2200uF (yes, massive, but i just happened to had them lying arround... something like 470uF would do just as good), and it worked wonders for lowering the noise floor.
miguel2 said:Do the cdrom drives have an I2S output? If they do, a very simple and cheap directly connected TDA1543 would the the rest...
Miguel
only players with philips mechanism have one; I think
Saurav said:
I'm looking for recommendations for a CD player.
I personally would suggest the Jolida JD-100. Its robust, has an awesome transport, is built like a tank (27lbs!), has an awesome remote, and has great sound for the money. You can buy one NEW from www.cattylink.com, though it will be a 220volt model (thats what step up/downs tranny's are for) for about $400+ (thats an awesome price considering that in the US they are still going for $900+) for a used unit it would be up to you and the seller....
