Load it on SVCS if you want to find the best sweet spot for any tube; then vary plate voltage and cathode resistance in order to find it. It is usually wide enough allowing a huge swing of an output signal.
I found this link for SVCS...
http://www05.abb.com/global/scot/scot221.nsf/veritydisplay/c9f996d4f6c5c601c12570c9004b1754/$file/a02-0196%20e%20lr.pdf
I think I would get arrested or shot now days if I tried.
How would I find the correct piece?
Try a shunt regulator instead
