Does anyone know of any inexpensive or freeware that simulates active crossovers on "real" speakers?
My thought is to record samples into a .wav or even .mp3 file then process via software into a High Pass and Low Pass. Each section crossover characteristics can be processed with variations in crossover frequency, slope, q, baffle step compensation etc.
These sections are then recombined and played back through via the soundcard into the actual speakers inside the room. This way, it is a simple process to experiment to home in on the optimal parameters.
Using multi channel sound cards, even multi way simulation is possible.
Exactly what kx-project is about.Using multi channel sound cards, even multi way simulation is possible.
There have been many people reporting good results with it.
I still have to change my soundcard....
http://www.pvconsultants.com/audio/dsp/dplay.htm
http://pcazeles.perso.cegetel.net/acxo.htm
Is two other options
Morten
Morten
This thread...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=41278
Can't beat dragging sliders and turning knobs to adjust while the music's playing!
if u've already have winamp and use it daily, there's also this plugin
http://www.winamp.com/plugins/details.php?id=4591
sqlkev said:if u've already have winamp and use it daily, there's also this plugin
If you wanna try a really powerfull equalizer, check this one
http://www.winamp.com/plugins/details.php?id=133877
Its a 128 band ( ! ) eq with curve drawing capability and five memories. I equalized my cheap Creative cambridge soundworks pc speakers using this eq and an RTA and the sound improvment was amasing.
- Real PC Simulation of Crossover?
