I plan to make DIY cables to connect my single ended unbalanced preamp (RCA output sockets) to a poweramp with balanced XLR inputs.
I have searched this site and found an extensive overview of possibilities here
http://www.diyaudio.com/forums/showthread.php?s=&threadid=3298&perpage=10&highlight=&pagenumber=3
Scroll half way down and look at number 17, "From output RCA to XLR input".
The shield connects to the input end only (at the XLR pin1).
I always thought that "pseudo-balanced" cables must have the shield connected at the output end (in this case the sleeve of the RCA plug) and NOT connected to the input plug sleeve/ground.
This is the case if RCA plugs are in both ends of a "pseudo-balaced" RCA to RCA cable.
I believe there is nothing wrong with connecting the shield at both ends, see attached pic.
So the 1000$ question is: Is No. 17 correct, is my suggestion (attachment) correct or should the shield in my pic only connect to the RCA sleeve and not to the XLR pin1?
What is actually the best way to make a RCA to XLR cable?
Frank Berry said:I agree with audiopro.
"Connect pins 1 and 3 together at the XLR and connect the shield at the RCA".
By doing it this way, there will be no audio current flowing through the shield.
This can be confusing as your statement is only correct if he still uses balanced cable and uses the cold wire to connect to the RCA. This has the disadvantage though that open ended shields have the possibility to act as a handy RF antenna.
If he uses ordinary screened cable and connects as you say there will be audio current flowing in the shield this way: audio is an AC signal and thus will be looping round the signal and screen.
klitgt, your proposed diagram is correct. I suggest that you connect that way, NOT connecting pins shield and cold together at the XLR as that will not offer any rejection of possible ground current in the shield. This also complies with the latest AES guidance.
audiopro said:Your diagram is fine, your worrying over nothing. Alternatively though, connect pins 1 and 3 together at the XLR and connect the shield at the RCA. I prefer to have the shield connected at the source end only.
So you suggest that the recipe here
should be reversed as to the connection of the shield (to the RCA sleeve and not to the XLR ground pin1) AND that the XLR cold pin3 is connected to the XLR ground pin1.
Both suggestions will leave an open ended shield that richie00boy does not recommend as he believes it will create a "handy RF antenna".
For info I use a cable that has 2 leads (each isolated) surrounded by a shield and then an outer isolating tube.
I will go for my original suggestion until I see other convincing solutions to the challenge (as I prefer to call what many call problems)
Hi
Best place for that kind of information...
http://www.vandenhul.com/artpap/wiring.htm
Very detailed and comprehensive..
Sorry to bump a 12-year old thread, but I have a newbie question: Apparently the output side versus the input side makes a difference? Trying to patch mono RCA-out to XLR- in and hunting down the spurious rf when I followed that illustration #17 mentioned in the very first post. Going to solder up kilgt's suggestion #2 today, but I'm sorta curious about the theories about why/how grounding the shield works in this situation.
It would depend on the specific set up. Are you referring to #17 in this Rane note? Sound System Interconnection In this instance it would be preferable to ground the shield at the XLR regardless of whether it's at the input or output since the opportunity is presented to keep the signal return separate from the shield.
- Design & Build
- Parts
- RCA to XLR cable, where to connect the sleeve?
