I try to home make some long interconnect (about 12 feet long from preamp to power amp) using name brand cables. But I've found that most of these cables have 3 wires inside ,some has 4. I was wondering how does someone using these wires to make interconnects. I thought one is for signal the other for ground. Any ideas?
Pete
Pete
No. I am actually interested in Kimber Kable and it's configuration. In it, three wires are braided together. I am just wondering if two of these wires are put together as signal path and the third as ground, or, one as signal path the rest two as ground. Or, one as signal path ,the second as ground the third non-functional.
