Raw Drivers - Free Shipping to US/Canada
EVERYTHING IS SOLD
1 Pair - USED Vifa BC14SG49 6-1/2" Woofer (Pulled from Meadowlark Osprey)
1 Pair - USED Vifa D25TG55 1" Poly Dome Tweeter (Pulled from Paradigm 3SE)
1 Pair - USED Paradigm 8" Woofer from Paradigm Phantom V2
1 Pair - USED Vifa D19 3/4" Soft Dome from Paradigm Phantom V2
Some Pro Drivers:
1 Pair - NEW 10" Pro Carbon Fiber Woofers -
1 Unit - NEW 6-1/2" Pro Carbon Fiber Coaxial c/w HF Compression Driver -
1 Unit - USED 10" Pro Paper Woofer -
SOLD
Model Number Correction on Scanspeak
I couldn't find datasheets on the Scanspeak and SB Acoustics mids you have listed, are the ones you have different from the 15W/4524T and SB12NRX25-04?
The SB Acoustics midwoofer is correct, the F in the model number
signifies a FOAM surround which doesn't suffer from the "rubber surround" dip which usually occurs between 1 - 2kHz.
For the Scanspeak, you are correct, and I corrected the model # in the original posting above.
I lowered prices slightly.
UPDATED
I have the following drivers available for sale:
1 Pair - USED MINT Scanspeak 15W/4524T Midwoofer (6" Fiberglass; Double Magnet, Copper Cap/Sleeve) - $95/pair
1 Pair - USED Vifa BC14SG49 6-1/2" Woofer (Pulled from Meadowlark Osprey) - $30/Pair
1 Pair - 1 USED & 1 NEW Fountek FW168 7" Aluminum Midwoofer with Phase Plug (dimple on one; other NEW) - $60/pair
2 Pairs -NEW SB Acoustics SB12NRFX-04 4" Paper Midwoofer NEW in Box - $55/pr. or $100 for 4
1 Pair - USED Vifa D25TG55 1" Poly Dome Tweeter (Pulled from Paradigm 3SE) - $30/pair
1 Pair - USED Paradigm 8" Woofer from Paradigm Phantom V2 - $40/pair
1 Pair - USED Vifa D19 3/4" Soft Dome from Paradigm Phantom V2 - $30/pair
1 Pair - USED Bose 201 MK 2 - $40/pair
Some Pro Drivers:
1 Pair - NEW 10" Pro Carbon Fiber Woofers - $95/Pair
1 Unit - NEW 6-1/2" Pro Carbon Fiber Coaxial c/w HF Compression Driver - $35 for 1
1 Unit - USED 10" Pro Paper Woofer - $20 for 1
1 Unit - NEW 8" Pro Carbon Fiber Coaxial with HF Compression Driver - $50 for 1
All prices are in USD.
Shipping is FREE to US & Canada with a minimum $180 USD purchase
Shipping for Tweeters - $15 Flat Rate to Canada & US
Shipping for Woofers - $30 Flat Rate to Canada & US
Shipping to other countries will require slight premium.
Take it all $495 with FREE Shipping to Canada & US
Shoot me an OFFER!
