rAudio-1 (Arch-based music player for all Raspberry Pi's)
Oups! Sorry, forgot to mention it... So here is my setup:
RPi4 -> USB (data & power) -> Khadas Toneboard
And a few screenshots.
Hope this will help.
I am enjoyin rAudio-1
1) smooth CD playback listing to my old cd's
2) AirPlay shows the Album Art and other details.
3) Snapy interface
what i would like is a playback screen like PCP, its just that i am used to such a screen.
is there a way to mode the playback screen
1) How to remove or edit a NAS listing ? Can create but can't find remove or edit.
2) USB dac Creative Soundblaster XFi 5.1 output is very distorted. This dac works with other RPi distro (PCP/Moode/Volumio) other USB dac work with rAudio.
seems the mixer device is not found as the listing is blank.
Well here I am again, same issue (8/25/22 post) with the current version, 20230630. Multiroom playback worked fine for a while but then it just stopped working. Not sure why so as a stand alone it worked fine so I just used that. Recently decided to update both units to see if I could get things working again but neither unit would update so I downloaded/installed the current version and tried to setup multiform playback with no luck. I'm sure it's just an incorrect setting or not turning some feature off/on. Can anyone shed some light on the steps they used to enable & use multiform playback? Any advice would be appreciated.
