Rattle can a power transformer
I scored a magnavox 93 series chassis on the curb this week. Its power transformer was covered in pitch or some type of potting. I got the power transformer stripped down to the almost metal with a metal brush and i got the paint stripped off the end bells (still alittle surface rust).
How can i paint the transformer with a spray can? I dont think i can get the endbells off without snapping the heads off the bolts. I have a spray can of black vynal dye thats super thin and meant for dash boards. My concern was putting too thick of a paint layer on to the point that the transformer wont be able to radiate heat well.
Really i want to spray the thing down with truck bed liner but i think that will really insulate it.
I wouldn't worry about it too much. I've worked with a similar Magnavox amp with a similar potted transformer. I believe it is typical for Magnavox.
Mask off the leads and hang it up in the air and wipe it off with paint thinner. Let it dry good and spray it with a good black enamel paint in two or three thin coats.
With the potting and construction they used, a couple thin coats of paint won't do anything to heat loss.
Any tips on painting the aluminum chassis? Ive taking a brillo pad to it, tryed hammered metal paint, that didnt stick, tryed stock flat black primer, that didnt stick. I got a feeling im going to have to just brillo pad in one direction and call it brushed aluminum since nothing sticks to it unless i spend $50-100 to paint 1 square foot.
Painting aluminum plus Magnavox use
I have had luck with first using some 220 grit papar on the aluminum and then using rustoleum hammered. The note by someone else concerning self etching primor works well too but it doesn't seem to like the hammered paint.
I have been playing with a Magnavox mono amp with 4 6V6's, 2-5Y3's and 1 12AX7. I replaced the 12AX7 with a preamp driver phase inverter system based on the Pilot 410 amp. 6C4 as a triode preamp, then 1\2 the 12AU7 as a voltage amplifier and the other half as a phase inverter. It alsways has worked perfectly with these types of amps and is very easy to work with. This time I have an issue with the scope trace. Just after the peak I get "fuzz" (sorry best description) I can post a picture of this trace if someone can tell me how to do it.
I traced my way through the circuit and have a perfect sine wave at the plate of the phase inverter and the fuzz at the cathode. Amp doesn't sound bad, it just doesn't sound as goood as I expect it to. Voltages all close to what they should be. Power supply completely rebuilt
Bruce
I have had no problem painting aluminum chassis. The finish seems solid with the only chips coming from removing the transformers after they were bolted down for several months. Some of the paint was stuck to the transformer legs. It won't be visible once I put it back together.
Aluminum oxidizes very quickly. The oxide coating will easilly scratch off taking the paine with it. Clean and rough up the finish as you described. I use a Scotch Brite pad. Wipe down the surface with a paper towel soaked in lacquer thinner and paint it as soon as the surface dries (a few seconds). I use Rustoleum rattle can paint (usually flat black) for the first coat. The coat should be thin enough to barely cover the metal. I put down several more coats as each one dries, which is maybe 10 minutes in the hot Florida sun.
I let that dry for a few days in a hot environment. I use a closed car that I won't be driving for a few days. Then wipe again with lacquer thinner and apply the final color coat.
This one was done in "Stone" paint from Home Depot. The OPT end bells were ugly grey rusted power transformer covers rescued from scrapped HP audio oscillators that were left outside in the Florida rain. I used the same method except the final coat was Rustoleum glossy black.
.....as each one dries, which is maybe 10 minutes in the hot Florida sun.
If you don't have 'natural heat' where you live, you can bake the chassis (without electronics!) in the oven at low (under 200 F) heat for a few hours.
Timing is critical- do this when you are home alone for best WAF!:D Put on the range fan and open a window.
A few afternoons hanging on the clothes line outdoors seem to help the paint harden up as well.
All this is just to speed up the natural paint hardening, which can take a month or so.
