Hello, I hope you are well.
I am new to the forum, my English is not very good, I hope they know excuse.
I have a problem with the pedal tonepad The Rat.
Well, after having a bad accident with the first attempt by Proco Rat, I decided to make the Tonepad, as many told me that I worked very well.
I did everything, PCB, soldering, etc.., But I get the same problem as with the first, if I put the volume pot half hummmmmm is heard, but the guitar sounds, if you put to the maximum or minimum disappears but the guitar does not sound either, I went crazy looking for what may be the error.
The first thing I did was to give the page Stomps, I was really going crazy this as more than 2 weeks ago I am for him and not get it to work. It will replace the potentiometers in case, but neither worked.
I hope I can help and can not find the solution anywhere.
The transistor is a BF245C, the diodes are 1N4148, the IC is LM308N, because here I could not get all the components that request.
I leave some pictures and voltage itself.
Thank you.
9v Battery --- 8.51v
IC LM308N
1- 0.02
2- 0.80
3- 2.07
4- 0
5- 0
6- 0.74
7- 8.49
8- 0.02
Transistor BF245C
G --- 0.00
S --- 4.09
D --- 8.48
Thank you.
IC LM308N
1- 0.02
2- 0.80
3- 2.07
4- 0
5- 0
6- 0.74
7- 8.49
8- 0.02
Transistor BF245C
G --- 0.00
S --- 4.09
D --- 8.48
Mcgiver, La Rata (Tonepad's RAT) works fine.
First off all, you should be more patient.
Obviously, there are some errors in your RAT.
You did a good job, providing the IC, and transistor voltages.
There is something wrong with LM308N voltages. They should be something like this:
Pin 1 - 8.4v
Pin 2 - 4.5v
Pin 3 - 4.1v
Pin 4 - 0v
Pin 5 - 0v
Pin 6 - 4.5v
Pin 7 - 9v
Pin 8 - 4.6v
BF245 have different pinout than 2N5458 that is suggested by Tonepad.
BF245's pinout
2N5458's pinout
Is your BF245 properly oriented?
You should have posted this at
[url=http://www.diystompboxes.com/smfforum/]DIYstompboxes.com - Index
[/URL]
or
http://www.freestompboxes.org
Pin 1 - 8.4v
Pin 2 - 4.5v
Pin 3 - 4.1v
Pin 4 - 0v
Pin 5 - 0v
Pin 6 - 4.5v
Pin 7 - 9v
Pin 8 - 4.6v
BF245's pinout
2N5458's pinout
[/URL]
or
