RAAL 70-10D and Supravox 215 sign bic
HI , I want to know if the Raal sensibility is good to match my
Supravox 215 signature bicone (93 db).
Do i need at least 93db or more ? cap 3.3 6000htz mundorf
Ex-Moderator R.I.P.
Joined 2005
The cheap hornloaded Neo CD3.5HB Fountek might do the trick, 50USD around here
I would expect 3.3uf/6khz being low without xo on Supra
But at the prices of RAAL I would consider to cross the Supra active around 1khz, to a Beyma AMT "ribbon"
The Beyma would need just a very small amp :devilr:
fountek
ok... the Fountek CD 3.5 , give me the freq cut please.
I dont want to put a Crossover on my Supravox.
What do you think about the sensibility ( the same for both speaker
Fountek and Supravox ) ??? higher the better?
thank you to answer me. Claude
Ex-Moderator R.I.P.
Joined 2005
Without xo on Supra, I would say above 10khz
Mind you, I have never heard your driver, so I can only look at Supra site specs
Especially above 10khz the small Fountek neoCD1.0MB could work, but its not listed on Fountek site, so I have no clew where it comes from
Or else maybe look at the Fountek JP3.0
Another interesting option could be the Pioneer-TAD ART-55D, 72USD at E-speakers.com
Supposedly made especially to be used only above 9khz, and limited to that use
Well, if you can afford the new Raven point source, seems e-speaker has lowered price by 25%
But above 10khz, less will be fine
Oh, I can only suggest what would be my own considerations, may not be like yours, or even the best ;)
