Quiescent current drops when i touch the heatsink
To Simon and Michael : Trough elyts of PS comes from rectifier ripple peaks, which have opposite polarity and " run " also through ground connection. Because ground connection have not zero resistance, only on straigh geometrical middle are both deducted and " disturbance " have zero value. To this point you must connect input ( " signal " ) ground, but also load and all filtration grounds. If you do it by this way, you get quite " silent " amp ( with SNR over 120 dB ) :cool: .
