Lucky you.
At what ambient temperature, with which type of music and what is high level for you?
If the heatsinks only get moderately warm, you probably perceive <1 W average as high level, which could well be. Many people overestimate the amount of W needed for loud listening.
The Cryolites are 8 Ohm speakers. If they were 4 Ohm, you would not have had a lot of fun with your amplifier, whatever the heatsink. Twisted Pear Audio sells it for 8 Ohm loads for a reason.
A 22 V transformer will give you rails that sag to ~26,5 V, when loaded. That relaxes the situation a little to a worst case dissipation of 74 W per channel. Two LM4780 on one heatsink of that size looks like pushing your luck however. Even the Overture Design Guide recommends 0,89 K/W per IC, and that includes insulation washers and thermal grease and is known to be stretching the limits already.
