questions about transfo
hi
For the low cost hammond 125ese transfo i read :
100hz to 15khz
max. dc bias = 80ma
that s mean ?? for the best linear operation ??:
- 80ma is really the max just before saturation (not linear)
and i have to cut to 40ma for best linear or 80ma is
the best point of bias ??
- if i drive this transfo with a low rp tube like 6as7 i
get better frequency low or high ?? or its a
misunderstanding of me
- for the bias is it the same principle for all company transfo
thanks
I believe 80mA is around where the OPT will saturate.
Have a read of some basic tests Joseph Esmillia did on the 125ESE here. Apparently it had not much trouble reproducing 20Hz-20kHz at 1W with a 2A3 with 60mA bias (the output valve and op point is important because the DC bias and the rp of the output valve will affect frequecy response).
jeapel said:
hi
100hz to 15khz
max. dc bias = 80ma
thanks
All single-ended trafos lose low-end when bias approaches max and it saturates. Use the trafo with bias lower than max to get more "bottom". The 125ese can go down to 20Hz with lower currents.
jeapel said:
ok lower bias=better bass good info but
therefore 125ese is only good for very
low 1w or 2 watt se amp not a good new
for my wallet :)
Well, Hammond doesn't advertise the 125ESE as a full-range "hifi" trafo but for $30US it is pretty good. I don't know about ultimate output but I do know that Steve at Angela has used the 125ESE in designs of more than 2 watts!
Here in the US a James 6123HS is $90US and it is a very nice trafo. The smaller James is even less if you can use a lower Z.
I check the 6123HS and find a discussion with
hammond 1628 vs james 6123HS
and now are you happy with the nice looking james
but give me details
1-your B+
2-2.5 3.5 or 5 tap
3-output tube +bias
4-feedback or no and output watt
5-and the sound :) or :-( or so so
but give me details
1-your B+
2-2.5 3.5 or 5 tap
3-output tube +bias
1- B+ is 430V
2- 5K tap
3- 80mA
4- output- initial measurement indicates somewhere between 6
and 8 but I'm going to give them several more hours of burn
in time before really measuring. Plus I'm waiting for a new
8 ohm dummy load as my previous one has gone missing.
5- sound is excellent. Base is deep and full, highs are crisp and clean and the midrange is smooth and detailed. (Plus it does look really nice! :D
6- You didn't ask but I'm using the UL tap which at 5K is
about 35%
Schematic-
