Probably one for the MiniDSP team, in two parts:
Balanced inputs to the 2x8 - Is the input fully differential? Is it tolerant of dc voltage from either signal pin with respect to ground? My output stage has an offset of about 8v from hot and cold signals with repect to ground.
Balanced outputs from 2x8 - is there any DC on the output?
I haven't received my 2x8 yet (it's on its way), so can't just measure the outputs.
I'd like to get away without adding coupling caps.
OK - so no response from the designers, but I can now answer my own questions. Posting it in case anyone else wants to know.
So I guess the order fulfilment team are more responsive than tech support - nothing new there!
There appear to be caps on both analogue input and output stages (prior to the ADC and post DAC). DC coupling is therefore not an issue on the way in, and there is no significant level of DC on the output pins (ref to signal ground or + to - signal).
Enjoy
Enjoy
@ Goto,
Sorry for missing your post. Sounds like you posted on our forum in the mean time so please see our reply there.
Due to our current workload, easiest to post on MiniDSP :: Category Index these days if you need a fast answer knowing we spend more time.
DevTeam
DevTeam
