QSC 151 Amp Project
a single limiter will protect from "a wash of red" though. true, if you're buried in the limiter, you're gonna cook a VC. Hopefully the tech is doing his job in that regard though (should be very easy to tell if your HF amps are hitting limiters since it should sound of garbage).
