Unfortunately, the design depends on very low noise from the
(-) voltage rail. In the original, that rail is ground, so there is
no problem. In your proposed modification, the noise at the
Source of the Mosfet will be amplified.
I suggest that you simply tie the V+ and V- together to form
V+ and ground, with the positive at twice the original value.
