I picked up a pair of Pyramid PW1077X 10" subs the other day. Just gave $20 for the pair, box included. I know these are crap from the get go. Any way, I have looked around the web for some theil-small specs for these paper weights but cant find any. I cant seem to locate a website for Pyramid either. Does anyone know where I can locate some specs for these subs? I plan on playing with them for a while just to see what they can stand (power wise that is). Any help at all would be appreciated
Thanks, Cujo
Thanks, Cujo
Just for fun let's try a test. Google "loudspeaker forums" and tell us what the first three that come up.
Mine are:
Loudspeakers - Audioholics HT Forums
(offset) Bi-wiring from amp to speaker
Soundreproduction.com
Oops, this is way OT. Sorry guys but I'd like to see what GM gets.
Mine are:
/Way OT
With quotes "loudspeaker forums" I get:
Loudspeakers - Audioholics Home Theater Forums
(offset)Denon AVR 3805 and Polk Audio LSi9 ? [Archive] - Audioholics Home ...
Problem or now with loudspeaker's? - Forums at ModMyiFone.com ...
No quotes:
The same thing you did!
No quotes:
Ok well that's interesting. I seem to recall a little while ago doing a test and not having the same results from someone even closer than the short drive from Ontario.
EDIT: I should have said no quotes, sorry for the confusion.
EDIT 2: We should mention that the short drive from Vancouver (BC) to Toronto (Ontario) is a mere 4412 km.
being halfway between you guys but a ways south, I get:
diyAudio Forums Archive - Loudspeakers
using quotes I get:
diyAudio Forums Archive - "fisss" on the 6C33C-pp
diyAudio Forums Archive - First time caller, long time listener...
the third a "subhit" of the second
using quotes I get:
- Subwoofers
- Pyramid Power
