PP mr horn will has but waiting i build! lol if change this to BLH it's possible to be.
Thanks: ฝากรูป dictionary
How high is 'and up'?
You could do it with the plenum (as per my PPSL) up to 800hz or so without much problem, or use a sloped plenum (like Electro-Voice did) with dual 15s up to 800hz or so.
If you did it the way of the M&K photo you could load the front firing driver into a phase plug, and mount the phase plug on the magnet of the other driver.
So, how high is up?
I have been meaning to try this with some 6-1/2" drivers (EV style slant plenum). This could mount to a big horn and just put a single wedge on the vertical faces between the plenums (look at bit like ax-heads).
So, how high is up?
- Subwoofers
- push pull in MR horn?
