I am preparing to build pair of 2-way speakers and am going to use the crossover function in "Pure Music". I have a Soekris R2R dac and would purchase another to drive a pair of "Lazy Cat's "First One" amps for LR HPF and LPF. The volume will be controlled with "Pure Music". I have a DIYINHK usb to I2S adapter.
If my thinking is correct so far my question is, will I be able to split the I2S to feed both dac boards or do I purchase another usb to I2S adapter an split the usb to feed the adapters?
Thanks,
Evan
Thanks,
Evan
The DIYINHK usb to I2S adapter is an async usb interface with independent clock. I would be careful with mixing two independent clock domains in related audio streams - L/R channels, LF/HF branches. It would be no problem with adaptive interface hooked to the same USB controller as such combination has only one master clock - the clock of the USB controller.
Of course splitting the I2S lines to several dacs is OK from the clock POW - only single clock is used.
