I wouldn't use the lamp. A 12v lamp will blow relatively quickly at anything above about 15v and the amp could easily drive 20+v into the lamp/resistor.
Connect the resistor across the output and do whatever you were doing to make the amp draw current with the bias pot fully counter-clockwise. Does the resistor heat up?
Is there any DC voltage across the resistor when the amp is drawing excessive current?
- General Interest
- Car Audio
- punch 500x bias voltage
