Did you see post 26?
Does the 3rd op-amp supply switch on?
Yeah the original reads like 2K ohms out of circuit. I thought this amp used a normally closed switch, so the original in fact was not defective..Im assembling the amplifier... But the op amp nearest power supply does switch on....
Well I know the one that I took out originally was definitely no good. It read as a real pretty resistor. I changed both of them. Still didn't get it to work, then followed your advice. I am pretty confident they are functional parts. I put them back in stock. I would have changed them back out but these boards don't seem to like to be reworked many times. Thanks again Perry I learned something today.
- General Interest
- Car Audio
- Punch 45 PC-045C pre mosfet power supply help
