Do you think it will get too hot?
I know the first series regulation of the shunty gets too hot, and will need more aluminium.
I am also thinking of a slow fan.
you really need some holes (plenty of them ) in that bottom plate , same as in cover plate
fan is not necessary then
anyway - that's still just preamp ....... holes are sufficient and simple solution ( necessity)
Hi Zen Mod,
can shunty be driven only on the two outer voltage points +36 v and -36 V so that I get 72 V for an experiment or must the current always go over the midpoint "ground" and shunty will be damaged by my try to get 72 V?
I do not fire up until your answer!
I´ll drink coffee!
Or can I use the two 470 R, I used to adjust the voltage and nevertheless suck my 72 V at the outer points?
will be very nice to get an answer from you!
I´ll drink coffee!
well - ground is state of mind
you want 72V for som stage ?
OK - Shunty with xformer is giving ya +36, gnd , and -36
then connect just two wires for your next stage :
+36 is +Ub
-36 is gnd
leave Shunty's gnd not connected to next stage
it's same as that you are using two batteries in series , without connecting mid point to outer world
edit:
be sure that programmed Shunty's current is enough for load demands
+36 is +Ub
-36 is gnd
edit:
X 0.2
If you had seen Pass X0.2 preamp, thay used 10K resistor from Drain of output mosfet Q5,Q6 - Q7,Q8 connected to Drain of Q10 to cancel DC Offset
Anadigit
I have both shunty and pumpkins running. The output offset is very sensitive to air currents and causes a number of volts negative offset when cooled. The culprit is the constant current source transistor Q9.
My question I have is about stabilizing the offset using the same techniques used on the Aleph-X where a resistor is placed between the output and returned to the source of the differential pair Q1 and Q2. If this would work what values might be appropriate. Another technique used was a resistor from the outputs to ground. On the pumpkin R2 and R4 seem to provide this function.
Any ideas
BDP
Anadigit
That's a really good advice. I have made this modification, and the DC offset drifting is now much smaller.If you had seen Pass X0.2 preamp, thay used 10K resistor from Drain of output mosfet Q5,Q6 - Q7,Q8 connected to Drain of Q10 to cancel DC Offset
Anadigit
A bonus was that with single ended source and balanced output THD was reduced to ~1/8 of the previous measurement.
Have not had time to listen to the results yet...
Happy happy
Glad to hear that !!!
I used this method to control X0.2 with non capacitor output
Anadigit
Anadigit
Airmax Square
Just Do It !
By
NIKE
..... that means the difference between X0.2 and pumpkin concerning the core circuit is not very big?
at any case I´ll try this modification!
Just Do It !
By
NIKE
Hi Zen Mod,
<<in any case - good goal for programming CCS-es in Shunty is 2x load current , so 50% will be burnt in Shunty itself ; that way your circ will be fed with authority ...>>
thanks Zen Mod for your answer, I hope you don´t mind I put your answer here, maybe someone else can profit from your explanations!
I will look what current I need for Aleph P 1.7 and for my other preamp and I give you one of the current values and you may tell me the modification needed in CCS for one case.
The next change I will try to make myself....
O.K.?
O.K.?
Hi Zen Mod,
O.K.?
you have all needed info in Cook Book ;
but we need to chat a little , so every reason is good enough
name your goal , the we'll do some calculation here , even if that sort of scribings are completely on topic in this thread ........
- Pumpkin preamp - ordered by Steen , official making thread
