PSU Help
I am working on a power supply for a tube line stage. I need about 120V, though there is a CCS and anything from 110 to 130 is probably fine. The CCS will draw between 40 and 60mA (to be determined by what sounds best.) Attached is a first attempt at a design. Runnng it through the duncan amps program generates an error which can be alleviated by reducing the capacitance of the second cap to 250uF.
So, can anyone offer advice about what changes to make, whether I do indeed need to lower the value of the cap, or whether this will work as is. I am planning to use a torroid transformer (hence the hybrid rectifier), and as such I may need to add a voltage dropping resistor as the torroids I can find seem to jump from 117V which is probably a bit too low to 220V.
Thanks for any help.
