The subwoofer can (should) go below the desk.Moondog55 said:$ 4inches sounds a little small and 8inches won't fit on the desk SO I'll see if I can find some really cheap 6inch woofers.
Plug them in to the winISD freq. generator, measure with your ears. Cheapest way I've found.
You could go for something like http://www.diyaudio.com/forums/showthread.php?threadid=142027&highlight=eliminate+need+for+bsc
Which I've just made (using Visaton FRS8 drivers), which go to 60Hz and below at reasonable levels (that's an octave below Fs).
Would you like me to post the design for it?
You can use any full-range driver, but some will be better than others.
The volume of the rear box doesn't seem to matter. And I didn't include ports.
Chris
Chris
