Anyone used these? Cant find much info on them around the web, look suitable for a nice 2-way. Idealy would like something around the Volt LS201 but its no longer made.
Want a mid-bass that will be halfway between Studio and PA (relatively smooth but with good output and tight punchy bass). Looking at the ATC SCM19 as inspiration.
Cheers, Rob
Cheers, Rob
Hi Rob,
Volt FR220.1 Pro PA Range/Full range COAX (£165.96)
Volt BM220.8 Studio Range/Bass-midrange (£136.17)
https://www.wilmslow-audio.co.uk/catalog/index.php?manufacturers_id=17
Volt Loudspeakers - BM251.3
How do you compare (prices and all) between the two. More advantage(s) to the Volt or to the PD, in your opinion? I think that with the later, box is a little big(Fs?).
It's a 10"...
It's a 10"...
