I'm looking for a preamp for my new Trends TA-10.1 amplifier. I prefer it to be of small dimensions, have 3-4 inputs and a remote control. I would like to build it myself, but being new to the whole diy-thing, i consider a kit a good starting point. I've looked at kits from Dantimax, who sells both a passive (Remote3) and an actice preamp (RemPre). I'm happy with the output level of the Trends, so no gain is needed. I have two questions:
1) Are preamp kits from Dantimax recommendable? Or should i look somewhere else, within the pricerange ($200-$300)?
2) What are the pros and cons regarding passive vs. active. Is there any reason for going active, when i don't need the gain?
Delaney said:I'm looking for a preamp for my new Trends TA-10.1 amplifier. I prefer it to be of small dimensions, have 3-4 inputs and a remote control. I would like to build it myself, but being new to the whole diy-thing, i consider a kit a good starting point. I've looked at kits from Dantimax, who sells both a passive (Remote3) and an actice preamp (RemPre). I'm happy with the output level of the Trends, so no gain is needed. I have two questions:
even if I'm not in that sort of amplification - I can recommend Dantimax products ;
I know man behind operation for pretty long time ( several years ) and he's certainly man of expertise
to my knowledge - you can easily use passive version , because T amp have enough gain
Re: Re: Preamp kit. Dantimax maybe?
I'm happy to hear that you recommend Dantimax. Does anyone else have any experience regaring said company?
Regarding passive vs. active; I've read that if you choose to use a passive preamp, your preamp->amp connections shouldn't be too long. This doesn't clarify the issue for me. What are considered too long? 3"? 30"?
Re: Re: Re: Preamp kit. Dantimax maybe?
that really depends of driving capability of your source ;
with decent output stage - CD can drive even 2m cables
Delaney said:
..... What are considered too long? 3"? 30"?
Re: Re: Re: Re: Preamp kit. Dantimax maybe?
Yes, but what can a 10k pot drive?
My CD is a NAD S500. The cables from CD to preamp will be around 1m. (Does the length of source->preamp cables really matter?) I'm planning to place the Trends TA-10.1 right next to the preamp, keeping the preamp->power amp interconnects below 0.5m. This means that the speaker cables will be about 2-3m. But this shouldn't be a big deal, right?
Mikkel is a good guy.
- Preamp kit. Dantimax maybe?
