i have a musical fidelity A120 integrated which does not have a pre out originally. is it possible to modify it to have one so that i could wire it out to drive another pair of monoblocks?
some ideas/ccts on the suggestion is certainly appreciated. thks.
or would it be ok to put a pot between the cd output and the amps input. so that the pot can act as a volume control and signal spliter between the a120 and monoblock.
As ACD sad post schematic(if you have), than we w'll see.
But conect doble shilded cable for L+R to main or master
volume pot. Output for rec. isn't according with volume pot.
