Ppi pc1400
I just recieved another one of theese amps in for repair its missing alot of parts off the board.
power supply fets are missing which i believe are IRFZ44's
Outputs are missing Which i think are TIP35's and 36's
The next parts are missing wondering if someone knows what parts belong in theese locations
Q12
Q13
Q15
Q16
Q72
Q73
Q75
Q76
Theese locations are between the outputs
Any help would greatly be appericated
If this helps theese are the parts that are missing
Ok im putting this amp back together.
My question is do i still have a problem with this amp.
With no outputs in the amp The readings i get between the pads are.
For both Tip35's and Tip 36's
From pads
1-2:9.31 k ohms
1-3:16.9 ohms
2-3: 9.12 ohms
This is the mono version of this amp.
Wondering do the readings look ok or does it apper to have another problem?
