I got this in for repair and opened it up someone has been in this amp before and did a very bad repair job..
Anyone know what the correct power supply fets this amp has in it.
Right now the amp has RFP70N06'S as the fets but the have been replaced and the solder job looks terrible..
Are theese the correct fets ?? If not wondering what ones are the correct fets that belong in this amp??
Will theese rectifiers works in this amp as long as i put mica insulators under them?
NXP | BYW29E-200,127 | BYW29E Series 200 V 8 A Ultrafast Rugged Rectifier Diode - TO-220AC-2 - Future Electronics
Ok i triple checked the outputs in the right channel and all test fine..
I have 3.44 volts of DC on the right channel output..
It appears that the outputs have been changed at one point in time..
The amp idles around 5 amps of current..
Wondering do i need to re-set the bias in that channel just in case whoever replaced the outputs didnt do it ??
Ok placed the shunts on both headers.. The amps 2n6488's and 6491's like to get red hor ral quickly..
Also when the amp is first powerd on it makes my amp meter flutter back and fourth for 5 secs then idles around 3 amps..
I also turn both bias pots all the way down and tryed adjusting the dc offset pots but it doesnt make a difference..
Right channel has 3.86 volts on output
Left channel has 1.86 volts on output
- General Interest
- Car Audio
- PPI PC 21400
