I have the previous one as well, have to pull the cover...
Well crap, the bit that fits must be at work. Already had the a600.2V2 opened for recapping (taking forever) but hadn't planned on recapping the a600.2V1 until I was confident it was doable.
Let me grab some allens and bits from work tomorrow to bring home and snap some pics.
Ok i think i have most of this amp figured out.
Only thing i cant figure out is the regulators.
Im assuming they are using 2N6488 and 6491 for the regulators.
They are using a transistor connected to a diode then to the regulator 1 transistor is a MPSA56 would the other transistor be a MPSA06? Q24 does anyone know?
The Q24 on the amp I posted second pics from is a n 06 with a gray face. It's close to C15.
ppia600:
I don't take in any work that has to be shipped to me.
With the old amps, you have to make clamps to hold the semis down tightly to adjust the bias.
You can always contact me via email. A link to my email is on virtually every page of all of my websites.
That's ok, didn't realize you couldn't do that. I can't remember the address you gave me when I sent the amp to get the transformer replaced, was it near Metairie? Either way, I don't make trips that way often. There are tons of places claiming to service them, I will try and find a professional shop with a good reputation.
At this time, the driver board are only rarely repairable due to the pads and traces.
Has someone repaired it and used parts that are not compatible? The manufacturer of the driver boards used parts from at least 2 different semi manufacturers so the markings will not match on all of them.
As you can see there are 2 different boards with different part numbers and 1 transistor is blown on the board .
Also you can see someone replaced parts on 1 board
Wondering if these 2 different boards will work if i replace the transistor that's blown
- General Interest
- Car Audio
- PPI A600.2
