I don't think the DC offset adjustment has enough range but you should at least try to get it zeroed (at the speaker terminals) with that first. If it doesn't have enough range, confirm that the voltage on the outer terminals (not the center terminal) of both DC offset pots have the same voltage.
I havent messed with the pots yet.
I had the outputs out of the amp on the left channel and just soldered them back in.
Now the amp has 1.95 volts on the output for like 10 secs then goes to 0.2 volts and amp plays fine out of the left channel then after about 2 mins i get 1.95 volts on the output for a min then it goes back to 0
Do i need to adjust the pot still or what do i do from this point?
- General Interest
- Car Audio
- PPI A1200
