PP6550
I tried to mod in paint to show what I've done on an amp.
A different connect on the input tube, G2 resister 390 ohm to triode connect it, screen to cathode.
Constant current sink on the LTP, the trimmer pot is not necessary for 5% resistors that you measure and match. I've used the Russian ECC99 here, great driver tube. This is worth the effort to do! Mosfet configurations also will work.
I like a solid bias on the output tubes so I use adjustable fixed bias. I like the low end of the music where you can feel the speakers breathe.
For some power transformers missing the 70 volt tap, I use a small 6.3 to 110 100ma transformer backwards connected to a 5vac tap. That will give be about -90 volts DC. I use a voltage divider with pots to derive an adjustable neg bias range from -20 to -50VDC to tame the output tubes to 45 -50ma. If the B+ is around 500V, I increase the neg range, so -30 to -60VDC.
I did not add this to the markup, you should be able to do this.
I redrew one of my amps with a EF86 on the input and tried to match your circuit. It has Schade feedback on the outputs that can be left off. I also use a damper tube as a B+ delay device in the power supply, that can be converted to tube instead of solid state or just leave it out, no delay. I put blue leds under some of the tubes, power on indicator etc... that also can be left off.
I simplified the bias on the LTP, and it needs the heaters to be elevated in voltage due to the LTP cathode to heater can't exceed 100V....
I use larger coupling caps, PIO russian caps are nice, I prefer .3 to 1u. I like large caps in the B+ feeding the output transformers for the low end...
It was drawn for the iron that I had on hand at the time...
Food for thought...
  • 6550_amp.pdf
