Powersoft K8
Hi all.
A Powersoft K8 came in for repair due to water damage.
Upon repairing a track on the underside of the pcb, i also found
a bad voltage regulator.
Unfortunately it is cracked open and i am not able to see which one is it.
I am referring to U4 in the power amplifier section.
Here is a pic that might help.
You'll probably have thought of this, but is there an identical regulator doing the same job on the other channel?
I suppose looking at the voltage ratings of connected caps on the output would give you a ballpark idea of the o/p voltage.
I understand that powersoft are a bit cagey with their service data, unfortunately.
+/-175v remember there's step up to upgrade k series
+/- 175V very high with huge switching losses in IDLE
Amp perfect for bass
But High Voltage Mosfet will be slow with high rise and fall times
clarity will decrease in Mid and High
I like to know switching Frequency ?
I think something between 200 - 250 khz.
Does somebody want have schematic from K series ?
