I'm building an Eiclone monoblock stereo. It's an El34 ultralinear amp. Strangest thing. The tubes are not drawing any current. I've got like 570 vdc on the plates and -75 on the grids. It's not bad tubes....I've substituted two pairs and the same results. The tubes are drawing like 1 ma of current. The plates should be about 90 volts less. I'm baffled!
Thanks!
David
Thanks!
David
