TUBE MIC.
IMO take the original one and if you can post a circuit we can even improve that.
You may not like what the diodes do and if you don't have a stiff PSU that's well isolated from the rest of the amplification circuit you're bound to hear it in the recording.
Just my 2 euronickels,
PSU filter
Can you porvide more information on how to do it?
fdegrove said:Hi,
The tube PSU would certainly benefit from choke filtering and some good quality polypropylenes or PIOs behind it.
Cao.
CHOKE.
Here is a link to a fellow members' PSU.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=7066
The choke is where it says 5H/100mA and you can put it straight after the rectifier ( where you have this 1K5 5W resistor ) or you can put a small cap in front of it.
After that you can use your circuit as is.
The 48 V phantom supply you could do according to your second diagram.
The missing resistor to ground on the regulator will depend on the regulator type you use.
I have no idea about the powerconsuption of this supply but I suppose a standard LM317 should do the trick.
Ciao,
Ciao,
- Tubes / Valves
- power supply for tube preamp
