power supply for techno amp
You use 2x35V or 35-0-35 mains transformer. 300VA or thereabouts should work well.
I'd probably use 2x6800uF per rail.
If you mean, how would you build such a supply, you would use a schematic similar to this one:
You will want to use fuses in each amplifiers power supply rails.. 2A fast-blow should be sufficient.
