Hi
Would be nice if you would post this in Power Supply section, Hope that this thread will be move there...
So about your question... First where will you use your amp (car, or home...)? If car then you will probably go with push-pull, if for home then you have flyback, halfbride, forward converter... lot of them.
http://www.diyaudio.com/forums/showthread.php?s=&postid=1355993#post1355993
Hi also I'm thinking to try analog discrete power supply to full digital amplifier.
there are "positive side" schematic and inverting PNP->NPN, NPN->PNP can make "negative side". Power Tr can be changed to MOSFET.
when source voltage = 55V and output voltage=50V, output current = 3A, (150W) MOSFET power loss = 15W. so you need large heat sink.
