Just would like to know if anyone is using after market audiophile power cords for their headphone amps
The question also is wire gauge. If your house wiring is 14 gauge, does it make any sense using larger gauge cords such as 12 or 10 gauge feeding your equipment. Thanks for any feedback.
An isolation transformer, and a line conditioner, but good old regular power cord...
Can you recommend a good isolation transformer?
Just use any robust power cord.
You only need an isolation transformer if you have a problem with audible hum on the output, but in that case then the problem is most likely not the power connection but rather that your grounding can be improved like using the same power strip to power the whole setup.
- Headphone Systems
- Power cords for Headphone amps
