Heres a simulation of this amp, i built a similar version:
http://i.imgur.com/tqfNq.png
MJE340/350 with 2SD669 / 649
is it 2sd649 or 2sb649
YOu can use 2SD669 and 2SB649. http://www.datasheetcatalog.org/datasheet/HitachiSemiconductor/mXrvtwq.pdf
Q
which power supply good for nmos200?
pls post the pcb layout
The small power supply shown here will power 2 Nmos200 modules.
Nmos & Nbip series - Quasi's DIY Audio Site
Q
HI QUASI .
WHICH PSU/DC PROTECTION U RECOMEND FOR NMOS200?
IN THE SOFT START WHAT IS THE RELAY VALUE ?
The soft start cct and layout is here: Slow turn on cct - Quasi's DIY Audio Site
Use a relay like this (many brands) for both the soft start and the DC protect ccts.
http://www.fujitsu.com/downloads/MICRO/fcai/relays/vs.pdf
Cheers
Q
hi nmos
greetingsdo u have pcb filesfor making youramp want to make it hoping you can help me
thanking you
andrew lebon
YES have remove crowbar and so on
and add Over current protection (look 1703 Quasi posting) + relay Turn on and DC protection
Any complaints for faults ?
Who want PCB gerber files ? ... email me
regards
Hey AndrewT;
A tidy way of winding a toroid?
Probably, but this doesn't apply to my efforts. Here is how I do it. I figure it don't matter as long as the wire is tight. Anyway no-one will know once the tape is replaced.
The winding going on in this pic is over another secondary I wound last night. See, once the tape is on it's hard to see the work quality anyway....
Ok everybody...let me have it!
Cheers
PCB layout to etch
i like the latest posting of the NMOS amplifier good work everyone really good designs i'd like to get a pcb layout i can etch the one on page 365 doesn't seem to have that. I am also going to use the IRFP264 mosfets they seem pretty good and i have a batch of them lying around ready to use so i can't wait to bang one of these amps together and give it a good run. the other question i have is about heat. should a amplifier keep warm or run that way and why does T8 transistor be mounted in the heatsink what the reason behind having to do that. Is there any reason why you can't just put a flag heatsink on it and let it sit on the board all by its lonesome. If you put a fan on the heatsinks and run them every time the amp is on does this run the amplifier to cold. Just a few questions i had about the amp iam looking forward to putting a one of the latest NMOS500 together with the protection circuits on the board will be great to get the pcb layouts to etch thanks. Look forward to reading you guys replys
pcb dimensions of nmos500 and power supply for protection circuits
hi
One other question i had i couldn't find the exact dimension of the nmos500 amplifier pcb board so i can etch the exact size if i decide to do that particular layout design on quasi's site. Another question i was wondering about do most people here if running a 24v fan run it of the same winding or transformer as a preamp is running on or do most people put a seperate small transformer in to run the cooling fans and protection circuits i was mainly curious on the power supply schemes most people are using to run the preamp sections and protection circuits on the most of these power amplifiers that are made once again thanks for your input.
hi
Hi to all.
So i build 2 pcbs and now i want to buy a toroidal transformer...I will use 8Ω soundspeakers and i am thinking of going up to +-85V . Do u think this voltage is too big? Anyone have used it on that voltage?
Also, 800VA is enough? What is the efficiency of the amplifier?
- Power amp under development
