keypunch said:Hi Hari,
The board is looking progressing great.
Any reason some tracks have a dark line around them? It is a bit distracting is all.
The wire link beween R35/R17 may need to be made wider and if possible bolded so it is not mistaken as a track and some might think the link should connect to T7. If you take a look at quasi's visual effect to show the wire link in the NMOS350/500 you see the visual manner the wire link stands out while also so labled with text as you have added pointing to the wire link. Also make sure when you create the tracks only image this wirelink does not appear on the tracks image. The wirelink should only show in the "layout" version of the PCB image as does with the NMOS350/500.
John
Good point about the visual effect of the wire link. I've already made it a lot thicker and re-routed it to prevent any confusion. This wire link will not appear on the final artwork print as it is on another layer. The main tracks are all on the bottom layer, the component outlines and designators are on the top overlay and this wire link is on the bottom layer.
The dark outlines you see are the guide lines I used for the polygon fill. These again are on a different layer and will not be seen on the final artwork print.
Thanks to you guys this board is getting better and better. I think it will be a fitting tribute to Quasi's design.
Cheers
Hari
jethari said:2. I've managed to provide the star ground. But the line going to C2/R3 cannot be helped.
Hari
No I couldn't either, but it doesn't matter as these components are part of the same filter network.
Cheers
Q
Re: Post #1983 and Post #2012
Hari,
Something just struck me about the PDF you posted in Post #2012, then I checked Post #1983. Both of the PDFs in Post #2012 and Post #1983 appear to be smaller, perhaps about 10-20% the size, of the PDF I eMailed you after I was able to reduce the PDF to about 64Kb. If you can print both the PDF I eMailed you, one of the PDFs you created and then print from Protel your PCB image to confirm all the images print the correct PCB image size. You have added C11B and C13B since the PDF I eMailed you so the PCB will be a bit longer, but I think the PCB width should be the same. I have compared the width of the TO-247's and they seem smaller in the PDFs you have created than the one I created. If you have a TO-247 device handy you can also confirm which, if any, of the PDFs print the right size footprint for the TO-247 and match the leads pads for the TO-247 on the printouts.
Regards,
John L. Males
Willowdale, Ontario
Canada
15 July 2007 19:44
Official Quasi Thread Researcher
jethari said:Hi Quasi, Key and everybody else,
Here is the updated pcb layout with all the suggested corrections. Tell me what you think of it.
Hari
Hari,
Regards,
John L. Males
Willowdale, Ontario
Canada
15 July 2007 19:44
Re: Re: Post #1983 and Post #2012
Hari,
I have done some more research sourounding your PCB image size and the C11/C13 capacitors that have been concerning me for a while now.
I have compared your two posted PCBs to the NMOS200 TO-247 version quasi posted near the start of the year. I find both of your posted PCBs to have the TO-247 footprint smaller than the NMOS200 TO-247 and the PCB I emailed you. The NMOS200 TO-247 and the PCB I eMailed you TO-247 footprints are the same size.
Regarding the C11/C13 rail filter capacitors, I have had this feeling their footprint was too small due to the small dimension of 63V. I checked the quasi "Classic" PCB and the footprints for your C11 and C13 are smaller. C11 and C13 are about 23-25mm in diameter on the quasi "Classic" PCB. I measured the diameter of C11 and C13 on the image I used to create the PDF I eMailed you and C11 and C13 are 16mm in diameter. It may be for the compact PCB nature to use 63V capacitors for the single pair NMOS TO-247, but I think with two pairs of TO-247's one can certainly run rails at 63V or tad above with two pairs of TO-247s. You did indicate you wanted to create a "L" mounting PCB like the NMOS200, but be like the quasi "Classic" in all other respects. Perhaps you might want to consider using 200V 330uF's for C11/13/A/B. I have some APT4025BNs that derated can handle 200W each derated to 60C and I know of other APT devices and some IRF devices like IRFP250/460/260 that would need a higher rated C11/C13 working voltage. One of the reasons I created the single pair and two pair versions of the "classic" PCB was due to these higher power TO-247 devices quasi said would be interesting to use on the NMOS200 TO-247 PCB. Using two pairs of APT4025BNs allows for 400W which would be 200W/8 Ohms and 400W/4 Ohms derated to 60C. It seems that quasi has dimensioned these filter capacitors at greater than 2 x Vrail on the "Classic" NMOS. I am not sure if this was a design decision or based on what was in the quasi store in light of the NMOS200 C11/C13 being rated at 63V compared to 200V on the "Classic" PCB. I do know that the output MOSFET devices need a rating of 2 x VRail plus some spare per the answer I had in Post #1920. I suspect C11/C13 ideally would need to be the same for the same reasons the output MOSFETs need to have a Vdss rating of greater than 2 x VRail. That said, for the quasi NMOS200 designed for rails up to 50V (and Post #1337) and C11/C13 dimensioned at 63V.
Regards,
John L. Males
Willowdale, Ontario
Canada
15 July 2007 (19:45 -) 22:03
keypunch said:
Hari,
Regards,
John L. Males
Willowdale, Ontario
Canada
15 July 2007 19:44
Hari,
Regards,
John L. Males
Willowdale, Ontario
Canada
John
You're right there. I did not realize that for the nmos350 I would need higher voltage caps. I have now changed to a single 680/100V cap of 16mm dia. I checked some datasheets for caps and this dia is ok for this value.
Hari
John
Hari
it's not really the NMos350 that needs the higher voltage caps.
It's the transformer voltage that determines the cap voltage.
40Vac is the limit for 63Vdc caps.
50Vac is the limit for 80Vdc caps.
63Vac is the limit for 100Vdc caps.
Some builders use a higher margin than I do, so decide if you want to set your limits lower than suggested above.
AndrewT said:Hi,
Andrew
What I meant was that as I was originally modifying the nmos200 pcb layout to fit the nmos 350 schematic, I overlooked the cap voltage ratings. I will be using 65V DC rails and hence the choice of 100V caps. The limits you mention is an excellent guideline.
Hari
Hi jethari,
Please disregard this if it has been mentioned, explained or corrected before, just took a quick look.
Your decoupling caps C9, C10, C11 and C13 they all share an incredibly tiny ground trace while you have lots of PCB space available, why?
The loss in that trace will make decoupling less effective due to added trace resistance and C5 and C6 connected halfway will have bad ground reference.
Hari
4fun
This point is certainly NOT to be disregarded. Never thought of it that way. As you say there is definitely enough space for a larger ground trace. The only weak link would be the two wire links (no pun intended!). I guess that can be overcome by using pretty thick wire for the links.
Hari
Hari
Re: Re: Re: Post #1983 and Post #2012
It just occurred to me what the "L" in JLM stands for.
keypunch said:
Hari,
Regards,
John L. Males
Willowdale, Ontario
Canada
AndrewT said:Hi,
Depending on the application I use a 20 - 30% margin.
Cheers
Q
AndrewT said:Hi,
when you moved the tapping point for the output, the NFB must move with it. The NFB tapping should come off the same solder leg as the inductor.
Andrew
Thanks, I've shifted the wire link.
Hari
Quasi
I came across this mosfet from ST called STW20NM60. This is a 20A 600V device and the description on the datasheet is identical to that of the IRFP450. Would this be a viable alternative to the IRFP450? Maybe even a single pair version using 60V DC rails to drive 8 ohm speakers?
Hari
Hari
Hari,
The + trace of C11 to the + Rail needs to be much wider. Given the narrowist part of the + rail trace is about 1/2 of where C11 + trace goes to the + rail trace I would suggest there is lots of opportunity to make the C11 + trace as wide as the narrowist part of the + rail trace. That said then the C13 - trace to the -Rail should be made the same width as the C11 + trace will made.
Also, the narrowist part of the + and - rail traces should be the same width.
I think L1 was better off not being moved. Now you may have stray L1 related currents floating on one side of the output devices unless you wire link back to R35 point.
Regards,
John L. Males
Willowdale, Ontario
Canada
17 July 2007 22:10
Regards,
John L. Males
Willowdale, Ontario
Canada
17 July 2007 22:10
jethari said:Quasi
Hari
This looks like a better FET. How much can you get them for?
Cheers
Q
- Power amp under development
