This amp is the same design that many amp manufactors use..
This is the board where the Audio driverboard sits in front of a fan..
Amp powers up idels perfectly all rail and regualted voltages are correct..
Amp has very very low output u have to put your ear to the test spaeker in order to hear it..
Any ideas what might cause this??
Ok fixed that now i have another issue..
A screwdrive rolled across my bench and hit 1 of the outputs when that amp was powerd up..
had a big spark but it didnt blow the output ..
I removed the output and powerd the amp up again now it stuck in protection mode..
If i remove all the low side outputs amp will power up and idle fine..
I tryed to put 1 brand new output on the low side but as soon as i do the amp protects..
Would the driverboard be the most likely cause of this??
- General Interest
- Car Audio
- Power Acoustic OV1-5500D
