Questions :
The input wold most likely be a CD Player , presently an AMC CD8b .
But , also , various other inputs through the Parasound P/HP-850
Pre - Amp .
I don't know the values of the amp , but here is a schematic :
http://www.audiosector.com/lm4780 amp.pdf
David
Pre - Amp .
David
10k pot has a maximum output impedance of ~2k5.
The input impedance of the 4780 as shown is 22k. R0=22k sets Zin.
That gives a ratio of 22:2.5 for Zin:Rs of ~ 9:1, OK.
! and you have started building it.I don't know the values of the amp
Where can I get a soldering iron " Pointy " enough to do
those " almost touching " LM4780 pins ?? !! David
Use Gel Flux from the radio shack. That will cause the solder to flow where it should go. . . rather than ball up into a mess.
- Chip Amps
- Potentiometer Value :
